I'm looking into upgrading my current system and wanted advice on the upgrades. I'm looking to upgrade the GPU from a 1060 to a 2070 Super and not sure if I should upgrade the CPU as well. I'm currently on a X470 Mobo with a 1700x. I will mostly be gaming and some streaming with very light video editing and encoding. Any advice is welcomed.
https://linustechtips.com/topic/1175436-need-advice-gpu-cpu-related/
If you can afford it then yes. It's about an 17% bottleneck by CPU or just go for a 2060 super.
First watercooled System
Build Name: White Knight
OS: Windows 11 Pro 64-bit
Monitor: Alienware AW3423DWF 1800R Curved Ultrawide 3440x1440 QD-OLED 157hz 10 bit 0.1ms
Chassis: Lian Li 011 Dynamic EVO w/ 2x120mm Corsair QL RGB Fans on the bottom 1x120mm on back exhaust
Top Rad & Fans:  Corsair 54mm 360mm w/ 3x120mm Corsair ML Pro RGB Fans
Side Rad & Fans: Corsair 30mm 360mm w/ 3x120mm Corsair QL RGB Fans
Motherboard: Asrock X670E Steel Legend
CPU: AMD Ryzen 7 7800X3D w/ Corsair XC7 RGB Pro w/ Kyrosheet
Memory/RAM: Corsair Dominator RGB DDR5 2x16GB 32GB 6000Mhz
GPU: Asus GeForce RTX 4080 TUF w/ EK-Quantum Vector2 Nickel/Plexi & Backplate
Pump/Reservoir: Corsair XD5 RGB
Coolant: Corsair Clear
PSU: Lian Li Edge 1000W
Boot/OS SSD: Samsung 970 EVO Plus 500GB NVMe
WZ/2042 SSD: Samsung 850 EVO 250GB
Game SSD: Samsung 980 Pro 1TB
Performance/Editing HDD: Western Digital Black 1TB
Storage HDD: Western Digital Blue 1TB
Mouse: Razer Lancehead Tournament Edition/Razer Mamba
Mouse Mat: Corsair MM700 RGB
Keyboard: Razer Ornata Chroma
Microphone: Beacn Mic
Headset: Razer Blackshark v2 Pro
Eyewear/Glasses: Gunnar Optiks Razer FPS/Gamer Advantage Liquid
Camera: Razer Kiyo Pro/OBSBOT Meet SE
11 minutes ago, Kastun said:
I'm working with a $650 possibly $700 budget for upgrades. What CPU would you recommend.
3600/x or 3700/x I believe there would be no bottleneck then.
Bottleneck percentage calculators are complete bullshit, please don't use them.
Why are they useless? Here's an example:
Let's say you have a Ryzen 9 and a GTX 1650. In regular gaming situations, there will probably be a bottleneck(weak GPU for gaming, strong CPU for gaming). But, some games are heavily CPU bound(ie. CS:GO), there probably won't be a bottleneck.
Point is, a bottleneck is always present. Level of bottleneck always depends on the task. A "17% bottleneck" in one program, could be a lot more in another program that depends more on a weaker part, or a lot less.
1700x will do fine, 8 cores will be nice with your specified workloads. There are definitely better choices(Ryzen 1000 has quite bad frequency and single core performance), but the price for upgrading is not worth it. GPU upgrade is good. Save your money and wait for Ryzen 4000, that would probably be quite worth it for an upgrade(unless you are happy with performance). AMD promised AM4 compatibility till 2020, and you have a X-series board so they should be compatible with a BIOS update.
You can only upgrade to the RTX 2070S and get away with it. You can dramatically decrease the bottleneck by underclocking the GPU, or overcloking the CPU(which i wouldn't recommend, since Ryzens come with their clocks maximized to the optimal level.) The combination is OK overall.
Best thing to increase Ryzen performance is to get dual channel RAM at >=3000MHz
4 minutes ago, PyroTheWise said:
You could do a 2070 Super + Ryzen 5 3600 at 700 bucks USD.
This is a good choice, but like @ephesus.exesaid you can get away with saving money and not upgrading CPU. Although 3600 has less cores than 1700x the increase in IPC and frequency results in a higher multi-core performance
yes, very true.  There are lots of options at he price point for upgrades the OP posted.   I do have one question though:
Isn't the Ryzen 1700x max speed limited to 2667MHZ.   So any memory bought above that speed will be slowed down to match?
That is a good point though.  The op didn't specify the memory installed (speed/amount).  So buying a 3600 might require a memory upgrade as well to really optimize performance which would be a tight fit for 700 USD.
If I'm not wrong that's just the officially supported speed but the motherboard doesn't lock RAM speed, like B or H series motherboards on Intel platform. I think there are problems with 3200MHz and above with Ryzen 1000(don't know if these are fixed), but 3000Mhz seems to be a good spot. Also, tightening RAM timings is quite important, lowers RAM latency by quite a lot.
There's an idiot-proof tutorial on how to do this without any trial and error.
11 minutes ago, ephesus.exe said:
thanks, i forgot that. i forgot that so well, i have 2x 2666 sticks in my system. lol
2666 is actually ok with ryzen as long as your ram timings are good, follow this tutorial and that's the easiest way to decrease ram latency.
My Specs are:
Asus ROG STRIX X470
G.SKILL Ripjaw V 2x8GB 3000MHz
Ryzen 7 1700x
Gtx 1060 3GB
Be Quiet! 750W Gold cert PSU
I plan to upgrade the stock cooler to something better and am not currently planning to OC the CPU or GPU. I don't have a need to OC at the moment and don't want to ruin my parts doing it myself.
15 hours ago, Kastun said:
Stock cooler is fine(unless very high ambient temperatures or bad airflow in case) OC is not needed at this point too.
Would recommend tightening ram timings, takes like 10 minutes max not including the time taken to watch the tutorial.
16 hours ago, boey said:
