Corsair AIR-540 build *need suggestions and some help*!
ziggyman77
Firstly, I've gotten this build pretty well. It's running great and speedy. But i'm still unhappy with the pump/res combo i'm using and i need some better lighting and suggestions for mods. (just a bit of context)
Okay, so here it is my build with:
Case: Air-540 silver by corsair
MOBO: Asus m5a99FX pro R2.0
GFX: Asis GTX 660 Directcu2         (upgrading to GTX 780)
HDD: Generic hatachi 2tb
SSD: Samsung 840 EVO 120GB
CPU: AMD FX-8350 OC'd to 4.4 GHz
RADIATOR: XSPC EX240
PUMP: XSPC X20 750 Dual 5.25" Pump / Reservoir Combo
CPU BLOCK: XSPC Raystorm - AMD and Intel
Power supply: Thermaltake 600W TR2
And from the below pictures, send me things that will improve the looks of my system.
(also i need a new pump/res combo that isn't a bay device because as you see in the bottom right it's velcro'd in, look up my case for measurements in my other side of my case where it will be going.)
Okey dokey, now for some pics (Here is the gallery on dropbox if you prefer that: https://www.dropbox.com/sh/jf5gztxf55fbb3p/Asente-8Op)
20140218_132621.jpg?token_hash=AAEuPtHkh
20140218_132645.jpg?token_hash=AAEuPtHkh
20140218_132705.jpg?token_hash=AAEuPtHkh
20140218_132725.jpg?token_hash=AAEuPtHkh
20140218_132735.jpg?token_hash=AAEuPtHkh
I'm open to any suggestions, tips, tricks, wire managment and anything really.
I'm just trying to make this a REALLLY flashy system.
(also my coolant IS UV reactive so suggest me some UV lights!)
Watercool the GPU also and get a res that you can see in the case windows? Just to clean it up a bit and give it a better look.
I dont quite yet have the cash for any of my upgrades, im just looking for things in the future to work towards and save up. Also, i plan to cool the GPU when i get my GTX 780. Thanks :P
I'd look into replacing that pump/res combo soon. That model is prone to leaking.
Feel free to message me if you want to chat!
It's not near anything that it'd harm i did that on purpose, if anything it's get my carpet turning blue :P (its on the bottom where as the hdd is raised, even if all the fluid came out it'd not get to the HDD and everything in the case is raised beyond the point of damage)
Also, what'd be a good pump/res for me looking for under 100$ ish area
first of all, you can overclock the 8350 alot more than 4.4 ghz if youre willing to mess with the VCore a little, im gonna try for 5.0 ghz when i get my AIO
This is dependant what your ambient temp is, ofc.
also shouldnt this be in planning, instead of build logs
It's my build log, and i'm open to suggestions.
And i need to learn to OC a bit better
