Need help with apt update not working
Solved by PorkishPig,
Lutris for xubuntu 16.04 looks to be deprecated.
Try remove all existing PPA entries and download them again with:
sudo rm -rf /var/lib/apt/lists/* sudo rm -rf /etc/apt/sources.list.d/* sudo apt-get update
You can download a newer version of Lutris if necessary with:
sudo add-apt-repository ppa:lutris-team/lutris sudo apt-get update sudo apt-get install lutris
