isnt this already in the CPU bottleneck problem? i had something similar with my quadcore(R 3 1200) before i upgraded to my 3600.
I was having like 30-40 fps in some games. then upgrading to 3600, i jumped up to about 60-70 even 80 at times.(Ghost recon Wildlands)
the resolution might also be an issue there.
Im with the mentaility of "IF IM NOT SURE IF ITS ENOUGH COOLING, GO OVERKILL"
CURRENT PC SPECS
CPU             Ryzen 5 3600 (Formerly Ryzen 3 1200)
GPU             : ASUS RX 580 Dual OC (Formerly ASUS GTX 1060 but it got corroded for some odd reasons)
GPU COOOER      : ID Cooling Frostflow 120 VGA (Stock cooler overheats even when undervolted :()
MOBO            : MSI B350m Bazooka
MEMORY          Team Group Elite TUF DDR4 3600 Mhz CL 16
STORAGE         : Seagate Baracudda 1TB and Kingston SSD
PSU             : Thermaltake Lite power 550W (Gonna change soon as i dont trust this)
CASE            : Rakk Anyag Frost
CPU COOLER      : ID-Cooling SE 207
CASE FANS       : Mix of ID cooling fans, Corsair fans and Rakk Ounos (planned change to ID Cooling)
DISPLAY         : SpectrePro XTNS24 144hz Curved VA panel
MOUSE           : Logitech G603 Lightspeed
KEYBOARD        : Rakk Lam Ang
HEADSET         : Plantronics RIG 500HD
Kingston Hyper X Stinger
and a whole lot of LED everywhere(behind the monitor, behind the desk, behind the shelf of the PC mount and inside the case)
https://linustechtips.com/topic/1174858-low-fps/#findComment-13457067
The 2600K is old school, meaning it has a very low thermal threshold. It should not run above 72C under load. The base clock is supposed to be 3.4 GHz.
Check if your cpu cooler is mounted correctly and replace the thermal paste if necessary.
Make sure the heatsink is clear from dust and the case has good ventilation, especially exhaust.
https://linustechtips.com/topic/1174858-low-fps/#findComment-13457095
