I need help
Go to solution Solved by Shepherd_Strike,
13 hours ago, desiigner93 said:
If it didnt post idk but yeah i was just now shutting donw my pc and it didnt shut down instead gave me a black screen and i needed to forceshut down soo yeah im pissed off
Faulty card.
Okey so this is my problem, first time ever building pc i bought ryzen 5 2600, i bought some biostar a320 mobo new psu 550w non brand and i had old gpu that died (stopped displaying anything) and now im stuck with even older gpu (radeon hd 5450) so i used it at the beggining of build just to see if it works i used it a week or so and didnt have issues... now my pc after a while start stuttering a like nit bad bad but bad it pisses me off, even the sound starts to lag and i cant listen to anything i dont know why and im mad im litteraly on edge of braking everything
https://linustechtips.com/topic/1174780-i-need-help/
Btw wrong type of break. And have you checked your drivers for updates or rolled them back.
https://linustechtips.com/topic/1174780-i-need-help/#findComment-13456543
6 hours ago, desiigner93 said:
untill 2011 sry bad spelling then my parents bought new one with sapphire 5770 i think and that gpu has died recently as i mentioned
Ok so your card might be faulty, i had a 1070 that was stuttering in games and black screening on boot
https://linustechtips.com/topic/1174780-i-need-help/#findComment-13457811
https://linustechtips.com/topic/1174780-i-need-help/#findComment-13458681
