Is this a pretty good build? I already have a case and the power supply that is listed along with some mechanical hard drives for extra storage. I wanted to stay under $500 and if I'm honest I wanted to stay closer to $400.
Type|Item|Price
**CPU** | [AMD Ryzen 5 1600 (14nm) 3.2 GHz 6-Core Processor](https://pcpartpicker.com/product/mV98TW/amd-ryzen-5-1600-32ghz-6-core-processor-yd1600bbaebox) |-  (On amazon for ($85)
**Motherboard** | [Gigabyte B450M DS3H Micro ATX AM4 Motherboard](https://pcpartpicker.com/product/hpRzK8/gigabyte-b450m-ds3h-micro-atx-am4-motherboard-b450m-ds3h) | $72.99 @ B&H
**Memory** | [G.Skill Ripjaws V Series 8 GB (2 x 4 GB) DDR4-3200 Memory](https://pcpartpicker.com/product/D6RFf7/gskill-memory-f43200c16d8gvkb) | $47.99 @ Newegg
**Storage** | [Crucial BX500 120 GB 2.5" Solid State Drive](https://pcpartpicker.com/product/VqgzK8/crucial-bx500-120gb-25-solid-state-drive-ct120bx500ssd1) | $28.98 @ B&H
**Video Card** | [Asus GeForce GTX 1660 SUPER 6 GB TUF GAMING OC Video Card](https://pcpartpicker.com/product/CH4BD3/asus-geforce-gtx-1660-super-6-gb-tuf-gaming-oc-video-card-tuf-gtx1660s-o6g-gaming) |-      (On newegg for $230)
**Power Supply** | [SeaSonic S12II 520 W 80+ Bronze Certified ATX Power Supply](https://pcpartpicker.com/product/fZyFf7/seasonic-power-supply-s12ii520bronze) |-    (I already pulled this from a pc someone gave me)
 | **Total** | **$465**
https://pcpartpicker.com/list/qWKJRk
https://linustechtips.com/topic/1174431-first-pc-build/
ryzen 5 1600 (12nm) is cheaper and better than the ryzen 5 1600 (14nm). the 12nm version is on par with ryzen 5 2600.
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1174431-first-pc-build/#findComment-13453774
The power supply is kinda bad so I'd replace it if possible. I made some changes, cheaper SSD and ram to make some room for a better motherboard.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1174431-first-pc-build/#findComment-13453797
Isn't the 12nm newer. I just bought it for a friend on Amazon for only $85. Performance is a steal for the money I've heard.
https://linustechtips.com/topic/1174431-first-pc-build/#findComment-13453842
yes it is
https://linustechtips.com/topic/1174431-first-pc-build/#findComment-13453849
Type|Item|Price
The Ds3h is an entry level mobo, I would not recommend it for r5
https://linustechtips.com/topic/1174431-first-pc-build/#findComment-13454022
