Ok so basically I am very confused, I want to buy some extra ram for my laptop, and currently I have 8GB installed. As far as I am concerned I need that the new ram to be the same freq as the old one, so I decided to check both task manager and Cpu-Z, and I got different results, can someone help me?
image.png.34c06905be0e55db2acd60ec03510803.pngimage.png.f314881f5373971b7f9450eee7f219f6.pngimage.png.6b5caa68de7934c7b39d04e2de312b41.png
https://linustechtips.com/topic/1174031-cpu-z-memory-read-out/
As what @yaboistar said.  I would just to make sure open up the laptop to look at the Memory you have now for 2 reasons:
1.  This will tell you if you have an open slot to add more memory
2.  You can get the exact part number of the ram in the laptop so there is no question as to the speed.
You might even be able to buy a matching stick if the memory is consumer based (or something really close to it).
https://linustechtips.com/topic/1174031-cpu-z-memory-read-out/#findComment-13450443
I do have a free slot because when I select slot 2 its empty, and in task manager it's slot 1 of 2. Also, what's XMP and how do I enable it?
https://linustechtips.com/topic/1174031-cpu-z-memory-read-out/#findComment-13450452
