The fan doesn't usually run when it is in rest-mode (download might cause it to run). Wear on the system is very small. Modern systems are designed to operate like this.
Most likely your PS4 will die because of other reasons. Or becomes obsolete when you eventually get a new console. No need to worry.
https://linustechtips.com/topic/1173869-i-need-help/#findComment-13449292
