Hi there, on my recently built PC (specs on the signature) I have POST problems. Since when I enabled DOCP, sometimes the system doesn't even post. When it does post, then it loads the OS without any problem and there's no issue at all. But many times, let's say 5 times out of 10, it does not post and it just remains stuck with a blank screen. The reset button doesn't work and the only way to power off is holding the power button for 10 seconds.Most of the times it does that only once and then it boots, but every once in a while it can go into that stuck state many times in a row before "reawakening", making me waste a lot of time. As soon as I turned off the DOCP the problem vanished. WTF?  Could it be a model of RAM not 100% compatible with the motherboard? Thanks
CPU: AMD Ryzen 9 5900X | Motherboard: Asus Prime X570-P | RAM: G.Skill Aegis 2x16GB PC 3200 F4-3200C16D-32GIS  | GPU: MSI Geforce RTX 4070 | PSU: Corsair TX750M | Cooling: Thermalright PA 120 SE
https://linustechtips.com/topic/1173805-pc-does-not-post-when-docp-in-on/
10 minutes ago, boggy77 said:
ram in slots 2 and 4?
Yes, in the slots suggested by the motherboard manual.
Update the boards BIOS to the latest version.
Main Rig:-
Server:-
That's the first thing I did :(
