So, I went to boot up my PC on a new monitor. The PC booted up just fine and the monitor was detecting signal, but not displaying video. Tried a different port, same thing (Switched from DVI to HDMI), I also tried different ports on my monitor with no luck.
When the PC is turned on, the monitor will detect signal, but will display the input as being DVI instead of HDMI. I started off in the DVI port of my graphics card with an adapter from DVI to HDMI. This detected it as DVI through the monitor, but no video was showing. I switched to HDMI but with the same results.
My monitor does not have native DVI, there are only 2 HDMI ports on it
https://linustechtips.com/topic/1173792-display-issues/
