Need Help Picking A Ryzen CPU
Go to solution Solved by pstarlord,
If I were choosing a CPU for that, depending on budget, I'd go 3900x or 3950x.
Hello,
Im looking to put a Ryzen cpu in a system I have, its going to be playing cpu instesive games plus its going to run about 12 minecraft servers in the background and I want somehead room for the future what Ryzen cpu should I pick?
Ryzen 9 3950x, GTX 1050 2GB, MSI X570 Gaming Pro Carbon, 1TB HDD 256 NVME SSD
https://linustechtips.com/topic/1173555-need-help-picking-a-ryzen-cpu/
Sorry, Yes they will be using lots of mods and plugins about 30-50 and all the servers will be linked to one.
and I want to hold about 100-500 players at anyone time.
where do you get the player base from
and i would look up what you would get recomded if you host at a company splamm in more ram a bit better cpu and ready
and also 100-500 per server or at all together
the player base would be from my old server
and i would like to host at pc from home because i get more control over what im doing.
and 100-500 all together
