First of all I would like to say thank you to anyone who helps me out, I need to upgrade my graphics card ASAP, i have roughly $650 burning a hole in my pocket and am currently gaming on an RX550 which is basically integrated graphics. I want to play all the AAA titles at close to max settings at 1440p 144hz(free sync).
Should I buy a card now? If yes which one?
or should I wait for “big Navi” or next gen Nvidia?
My current build is down below
https://linustechtips.com/topic/1173034-graphics-cards-help/
you're definitely not gonna do that with a $650 budget, that's 2080 ti levels of performance (and even that is not sufficient for rock solid 144 fps)
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1173034-graphics-cards-help/#findComment-13442452
