Just remember the pre-painting work, and use the right paint!
Network/Homelab build log Main PC: "Aqua Blue"  Server: 15TB+ "Blue Lightning"
3900x, 32GB RAM @3200mhz, RTX 3090, 2.5TB+ SSD Storage, 4x2560x1440 monitors
Samsung Galaxy Z Fold2 5G, +2x Note 9
https://linustechtips.com/topic/11729-help-with-painting-a-case/#findComment-125048
use a wet and dry sand paper, the spray with 2 layers or primer (Black for dark colour white for bright colour) then spray with your wanted colour.
its easier 1s you take apart the entire computer, individual panels make life easier and gives a cleaner finish.
make sure you remove the front connectors and spray at a distance of about 13 inches to give a better finish.
also don't forget to do a few layers of paint. loads of people dont bother with this but it gives the cleanest finish
Character artist in the Games industry.
https://linustechtips.com/topic/11729-help-with-painting-a-case/#findComment-129139
  • 2 weeks later...
Hey, I'm interested in painting my case too, what kind of paint should we be using? Any specific brands that are good?
i put a guide up on how to do it, nothing specific but it is a basic guide and it covers both metal and plastic so:
http://linustechtips.com/main/topic/13502-basic-case-modding-guide/
https://linustechtips.com/topic/11729-help-with-painting-a-case/#findComment-161891
