Hello everyone I currently have a Pre-Built IBuyPower PC (https://pcpartpicker.com/list/GbwpNq)
I play modded GTA V with FiveM and I get around 25-38 FPS. I am wondering if I should upgrade my CPU or my GPU. I am on a budget so nothing to expensive, please reply with some suggestions! Thanks!
https://linustechtips.com/topic/1172355-need-some-help/
GPU, which one depends on budget
Desktop benching:
https://linustechtips.com/topic/1172355-need-some-help/#findComment-13437122
whats your setup baterry and watts on it current gpu and cpu and ill try to help also give me a budget
https://linustechtips.com/topic/1172355-need-some-help/#findComment-13437138
What screen resolution and budget?
Be sure to QUOTE or TAG me in your reply so I see it!
CPU Ryzen 7 5800X3D GPU EVGA 3080 Ti FTW3 Ultra MOBO Asus ROG Strix B550-F Gaming RAM Crucial Ballistix 3600 MHz CL16 32 GB PSU Corsair RM1000x COOLING Noctua NH-D15
https://linustechtips.com/topic/1172355-need-some-help/#findComment-13437246
Quote me or mention me at @Shrekpad so I get notified
pc specs:
CPU:
Intel i7 8700K MOBO: ROG Strix Z390-E Gaming RAM: 16GB (2x8) DDR4 G Skill TridentZ 3000 MHz GPU: Gigabyte GeForce RTX 2080 SUPER GAMING OC CASE: Phanteks Enthoo Evolv STORAGE: Sabrent Rocket Q 1TB M.2 NVME SSD,
T-Force Delta RGB 250GB SSD, 4TB Seagate Barracuda HDD PSU: 750 Watt EVGA SuperNova G3 MONITERDell S2716DGR 1440p 144hz G-Sync, BenQ PD2700U 4K 60hz CPU COOLER: Corsair H115i RGB Platinum OS: Windows 10
https://linustechtips.com/topic/1172355-need-some-help/#findComment-13439696
How would a 1050 TI do? Im looking for around the budget of one of those
Just tell us the exact number.and currency. 1050ti should.only be considered when buying used since it's discontinued already and prices of new ones are really high in most cases
Cards that dont need extra power connectors tends to be awful value for money as well. 1650 (75w, does not need power connector) costs as low as $150, 1650 Super (100w, needs a 6pin power connector) costs as low as $160 while being at least 1/3 faster.
Desktop benching:
https://linustechtips.com/topic/1172355-need-some-help/#findComment-13439889
