Hey I have a RTX2080 and I only had one concern.
works great but bent power pins for 8 pin PSU delivery?
is this bad for long run?
If you look closely, you see the  grey plastic square on GPU bent, but not the cable from the power supply, only where it plugs in.
Thank you SO much for your time!!!
https://linustechtips.com/topic/1172191-bent-power-delivery-gpu/
Based off the picture the only thing I see is electric tape to hide something - what bent pins?
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
As long as there is no tension on the cable, I wouldn't worry too much about it. If there's too much tension on it, it may eventually rip the socket off the PCB, but typically these kinds of connectors can take a bit of force because their contacts go completely through the PCB, and aren't simply glued down like USB ports.
You can “train” your cables to bent a bit more and don’t put so much tension on the power socket. And also for aesthetics you can get combs instead of the cable ties, will look much better with custom cables
   @Whiro tag or quote will do the trick
Steam Deck OLED 512gb , all other pc’s are gone
                                          WHIRO
         THE FIRST OF DEATH AND DARKNESS
        He feast on the dead to inherit their power
Make sure not to put your cables under too much tension and you'll be fine leave enough room in them so as to make sure you can easily unplug the cables from the gpu in future in case you wish to clean sell or upgrade your gpu
Oh really? ok! great to know. I didn't know that. is this one like this too? Thanks for your time.
So did it get like this from the tension of just from factory?
and thanks btw means alot.
good point! thanks for reply!
