Need Watercooling Advise
Go to solution Solved by Hold-Ma-Beer,
1 minute ago, BryanZeraph said:
So hi guys, I wanna get some advice for watercooling. Idk if the design below is efficient or not as the cpu only has single fan while the gpu has 2 fan. Is it good this way??
Ah, this really depends on the configuration you're going for. If you dont plan for any overclocks on the CPU, that single fan rad will be enough. I've seen 9900k ( non oc ) on that single fan rad with reasonable temps ^ . ^
