Quote
I was on my brothers laptop trying to change his mac address in registry and I deleted the Network folder containing what apparently was useful. I also in the 0002 folder with his driver desc for his wireless adapter created a "NetworkAddress" string and now the internet doesnt work I need helpspacer.pngspacer.pngspacer.pngspacer.png please dont hack me if you can with the information below i dont want to have to make him do a system reinstall
Kinda like below which is mine
https://linustechtips.com/topic/1171918-emergency-help/
Well can't say I've ever run into this particular issue, but I'd do a couple things:
1) uninstall network drivers, assuming they're still on there (only do this if you have another PC where you can download new ones, though)
2) get the drivers on another PC and install them from a USB
3) run
sfc /scannow
 in an elevated command prompt, it *should* repair broken windows installs to some extent
4) pray
Main Rig: R9 5950X @ PBO, RTX 3090, 64 GB DDR4 3666, InWin 101, Full Hardline Watercooling
Server: R7 1700X @ 4.0 GHz, GTX 1080 Ti, 32GB DDR4 3000, Cooler Master NR200P, Full Soft Watercooling
LAN Rig: R5 3600X @ PBO, RTX 2070, 32 GB DDR4 3200, Dan Case A4-SFV V4, 120mm AIO for the CPU
HTPC: i7-7700K @ 4.6 GHz, GTX 1050 Ti, 16 GB DDR4 3200, AliExpress K39, IS-47K Cooler
Router: R3 2200G @ stock, 4GB DDR4 2400, what are cases, stock cooler
I don't have a problem...
https://linustechtips.com/topic/1171918-emergency-help/#findComment-13433645
14 hours ago, Luckyprock said:
Bless your soul it worked without uninstalling anything
Glad to hear it. If you know what step fixed the issue, feel free to comment it below so others searching who find this know what worked. Also you can select an accepted/best answer if you feel it was helpful ;)
https://linustechtips.com/topic/1171918-emergency-help/#findComment-13435697
