Compatible CPU Installation?
Solved by Fasauceome,
35 minutes ago, bigustruckusmaximus said:assuming the drivers are up to date?
The CPU doesn't have drivers so you're fine. The 4820k and 4930k are also the same generation so a BIOS update would not be required either
kerriya ·
Posted in Cases and Mods8 -
octester ·
Posted in Troubleshooting6 -
DavidPatrascu ·
Posted in General Discussion7 -
2
3
bill well ·
Posted in Peripherals1 -
4
play_circle_filled
Latest From ShortCircuit:
