coprocessor Help
Go to solution Solved by Radium_Angel,
1 minute ago, Nolanrulesroblox said:
Sorry (i always forget something) Im using Vsphere as HyperVisor
See if this helps
https://www.pugetsystems.com/labs/hpc/Top-5-Xeon-Phi-Misconceptions-508/
Im thinking about buying one of these cards on ebay "Intel Xeon Phi 71S1P 8GB RAM 1.1GHz 61 core CoProcessor" for my server
my Tasks i do -- Video rendering (and editing) -- Folding@home -- Running an Apache2 Webserver with SQL databases -- Storage (Freenas)
Could it help with any of these? (my System is Fully Compatible)
the OS Vsphere
https://linustechtips.com/topic/1171347-coprocessor-help/
No.
These are for very specific functions, and don't run under Windows.
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
https://linustechtips.com/topic/1171347-coprocessor-help/#findComment-13428336
See if this helps
https://linustechtips.com/topic/1171347-coprocessor-help/#findComment-13428358
