Hi I could really do with some advice  about upgrading a PC I built a few years back. I mainly use the PC for gaming. I am currently running:
i3 6100
1060 3GB
8GB RAM
128GB SSD for OS and commonly used smaller programmes
1TB HD used for main storage
500W EVGA power supply
Gigabyte b150 G1.sniper B7 LGA1151 mobo
I am looking to upgrade this PC over the next few weeks. Should I buy a new mobo and a less powerful CPU(most likely lower end current gen i5/i3 or maybe an AMD equivalent) or buy a second hand CPU such as a higher end i5 (~7600)? Instead I could leave the CPU and buy a more powerful GPU. I am fairly sure I should buy another 8GB of RAM on the side.
Any help is much appreciated.
https://linustechtips.com/topic/1171180-upgrade-advice/
Do absolutely NOT buy a new GPU. If you want power, buy a new CPU. It''s either new mobo and new CPU, or buy secondhand CPU that fits current Mobo. the i7 6700K still works rather well, however you might need a Z170 for that, i've forgotten. Otherwise go with an i5 6600K.
https://linustechtips.com/topic/1171180-upgrade-advice/#findComment-13426773
Pick up a 1600AF and B450M Pro4/Pro VDH max instead of an i5, used prices for the i5 are too high to recommend.
https://linustechtips.com/topic/1171180-upgrade-advice/#findComment-13426796
How much should I expect to pay for a 1600AF as I am struggling to find many sellers? In general, when looking for a CPU for gaming is it more important to look at single thread rating/score or # of cores?
Is it worth going for a 7th gen CPU over a 6th gen? My mobo does not support overclocking so should I go for a "k" version or not?
Thankyou for your help :)
https://linustechtips.com/topic/1171180-upgrade-advice/#findComment-13426931
a 6-core i5/ryzen 5 CPU will be mostly fine for gaming now, though the i5 might start to stutter in games with higher-end GPUs.
https://linustechtips.com/topic/1171180-upgrade-advice/#findComment-13426951
Is the 6700/7700 overkill when paired with my GTX 1060 3GB? Would i be better off saving the money and putting this towards a GPU in the future?
https://linustechtips.com/topic/1171180-upgrade-advice/#findComment-13426959
its fine, plus the i5s will bottleneck anything that's a worthwhile upgrade from the 1060 3gb. Newegg still has the 1600AF for $100.
https://linustechtips.com/topic/1171180-upgrade-advice/#findComment-13426964
I'm in the UK where the 1600AF is out of stock on newegg and costs £136 as a second hand i5 6600 from a reputable brand will set me back £90.
https://linustechtips.com/topic/1171180-upgrade-advice/#findComment-13426974
it's 98 pounds on alza. spend the extra for the 1600AF or a 2600 instead of getting the i5, it will bottleneck anything past the 1060 6gb/rx 580.
https://linustechtips.com/topic/1171180-upgrade-advice/#findComment-13427011
okay, thank you for your help. I have never swapped CPU/MOBO before. Is it as simple as swapping them out or do I need to worry about OS/bios....?
https://linustechtips.com/topic/1171180-upgrade-advice/#findComment-13427048
you may need to install a few drivers depending on the board, but nothing major.
https://linustechtips.com/topic/1171180-upgrade-advice/#findComment-13427125
13 minutes ago, Hugh_Jassole said:
Okay, thank you for all your help :)
I'd recommend doing a full system reset, and then put files on an external harddrive or something that you'd want to save. Sometimes drivers might be hidden, or there's something left that will "piss off" new drivers.
https://linustechtips.com/topic/1171180-upgrade-advice/#findComment-13427161
I upgraded from an i7 860 to an engineering sample 10-core xeon, and from said xeon to a 4870HQ and now a 1700, which went through a motherboard upgrade. none of those instances needed any kind of windows 10 reinstalls.
https://linustechtips.com/topic/1171180-upgrade-advice/#findComment-13427454
