After finishing my first hardline custom loop I have had trouble hitting 5ghz without hitting 90+c(while running a stress test)on my cpu and Vrms. I have little experience with overclocking CPU’s and memory as with most of the pcs I’ve built I have left the bios almost untouched. I have tried messing with offset/tried to under-volt it but had no luck. I understand that the 9900k does run hot but not this hot, especially with a custom loop.
My rig
Cpu: i9 9900k
Motherboard: Msi z390 Godlike
Memory: Corsair dominator platinum 32gb 3600mhz
Gpu: Rtx 2080 ti kingpin/w hydrocopper
6 Corsair ll120 fans and an ek pe 360 mm rad
(I apologize for the poor image quality)
https://linustechtips.com/topic/1171105-overclocking-issues/
is the pump working correctly?
Bethesda PC:   R7 3700X  -  Asrock B550 Extreme 4  -  Corsair Dominator Platinum RGB 16GB@3.6GHz -  Zotac AMP Extreme 1080TI -  Samsung 860 Evo 256GB  -  WD Blue 2TB SSD -  500DX  -  Stock cooling lul  -  Rm650x
CrumpleBox V3:  Xeon X5680  -  Asus X58 Sabertooth  -  DDr3 16GB@1.33Ghz  -  Gigabyte 1660s -  TT smart RGB 700W  -
Cooler Master Storm Trooper  -  120GB Samsung 850 Pro   -  LTT Edition Chromax NH-D15 ?
CrumpleBox 3 ROTF: I5-6400  -  MSI B150m Mortar  -  16GB 2133Mhz Vengeance Pro RGB  -  Strix 1070Ti - GTX 1070 FE  -  Adata 128GB SSD  -  Fractal Design Define C  -  Gammaxx 400V2  -  Cooler Master silent pro gold 1000W
CrumpleBox 2: i7-7820x - MSI X299 Raider - 32GB Thermaltake Toughram 3.6Ghz - 2x Sapphire Nitro Fury - 128GB PCie Adata SSD - O11 Dynamic - EVGA CLC 360 - Corsair RM1000X
Perhiperals:  Gateway 900p60 monitor  -  Dell 1024x768@75  -  Logi. G403 Carbon  -  Logi. G502  -  SteSer. Arctis 5  -  SteSer. Rival 110 - Corsair Strafe RGB MK.2
https://linustechtips.com/topic/1171105-overclocking-issues/#findComment-13426037
2 minutes ago, ZeratorRules said:
Problem is with my current configuration I can’t fit two rads/ my gpu is just too large.
Well it looks really nice!
I had an issue many years ago. Ran out of room with my Antec 900 case. So I got my hands on a SilverStone Tj07. Never had a problem with space since. Didn't look as nice as your case though.
https://linustechtips.com/topic/1171105-overclocking-issues/#findComment-13426067
Do you have any other large case recommendations preferably with ample liquid cooling support/only because I had enough trouble putting this thing together as it is. The distribution block made it so much easier to route tubing
https://linustechtips.com/topic/1171105-overclocking-issues/#findComment-13426088
4 minutes ago, ZeratorRules said:
Fractal Design Define R6 Black TG is a nice case.
Maybe Phanteks, they make some really nice cases.
https://linustechtips.com/topic/1171105-overclocking-issues/#findComment-13426107
