What fan configuration would you guys recommend for better airflow? I've currently got the top 2 radiator fans setup at intakes with auto speed in the bios. Rear fan running at Full Speed Exhaust and Front 3 Fans running at Full Speed Intakes, AIO pump running at full speed. My only concern is I'm not sure if I should have the radiator fans as intake or exhaust? Photo is attached. Thanks for your help.
GPU is Overclocked to +100 Mhz on the Core and +750Mhz on the memory with maxxed out power/temp gauges.
CPU is Auto OCed in Ryzen Master.
https://linustechtips.com/topic/1170844-best-fan-setup/
Front intake and top exhaust is good.
https://linustechtips.com/topic/1170844-best-fan-setup/#findComment-13424629
2 minutes ago, StatikShockTTV said:
Would the hot air from the GPU affect the CPU temps in that setup?
Yes but it's not a big deal.
Make sure to quote a post or tag a member when replying or else they won't get a notification that you replied to them.
https://linustechtips.com/topic/1170844-best-fan-setup/#findComment-13424967
Better or best airflow?
I run 120x38s and they are awesome. They will blow away many popular referrals. Looks like you have a couple of rads.. perfect.
AMD R9 9900X | Thermalright FW Pro Black, 3x TL-B12E | Asus Strix X670E -F | 64GB G.Skill 6000C26
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 2x SN770 | Seasonic Vertex GX-1000 | ProArt PA602
Adcom GFP-345, Adcom GFA-555, S.M.S.L D1+PS100, Cerwin-Vega! CLSC-15, Monster HDP-1800
https://linustechtips.com/topic/1170844-best-fan-setup/#findComment-13425649
Either or @freeagent. I just swapped the top rad fans to exhaust, and now the GPU Idles at 32-34 Degrees, down from 40 at idle (60ish under load, down from 65), which is great, CPU idles at 42-44 and 70 high underload. What do you think of moving the radiator to the front and keep the fans as is right now, 1 rear exhaust, 2 top exhaust and 3 front intakes with 2 of those fans being on the rad? Think the cooling would be better than what it's at right now?
https://linustechtips.com/topic/1170844-best-fan-setup/#findComment-13425767
The cpu might get better cooling and the warmer air might be worse for the gpu. It's hard to tell what would happen without testing.
https://linustechtips.com/topic/1170844-best-fan-setup/#findComment-13425948
I agree you’d have to play with it. In my case my gpu idles at 25-27 and loads at about 60.
https://linustechtips.com/topic/1170844-best-fan-setup/#findComment-13426896
