i have errors with my films and tv, with microsoft photos and with microsoft store
should i just reinstall windows to fix it all?
if i reinstall will it fix that?
"I fear not the man who has practiced 10,000 kicks once, but I fear the man who has practiced one kick 10,000 times." - Bruce Lee
https://linustechtips.com/topic/1170701-errors/
Have you tried running the troubleshooter?
(thanks to MSFT for the instructions)
Run the troubleshooter: Select the Start  button, and then select Settings  > Update & Security   > Troubleshoot, and then from the list select Windows Store apps  > Run the troubleshooter.
Please mark as helpful and informative so my profile looks better.
quote or reply to me if you want me to reply to you.
Thanks
https://linustechtips.com/topic/1170701-errors/#findComment-13422723
yeah i did that already and it shows that microsoft photos are not installed on my pc as well as the microsoft store
both of them are not installed and i dont know what to do.
the films and tv app is always bugging out and im just tired of it
https://linustechtips.com/topic/1170701-errors/#findComment-13422769
