Hey,
i change my psu, motherboard and ram for about 8 months ago and 1 month ago i changed my cpu, i had some problems with booting my new cpu the dram cpu lights on my motherboard was flashing, but it ended op booting and was running for like 2 weeks but then one morning it would'nt boot it just kept going through the cpu dram lights, cpu light was red, dram orange, vga white and boot green.
now i change back to my old cpu it has no problems but some of my rgb is lighting is gone now, so im thinking my psu might be bad?
i have updated the bios on my motherboard btw.
specs:
new cpu ryzen 5 3600
old cpu ryzen 3 1200
motherboard asus b450-e
psu seasonic focus 550W platinum
gpu rx 570
ram 16gb g.skill ddr4
Is my psu or motherboard bad can't figure it out.
sorry for any bad spelling
https://linustechtips.com/topic/1170699-problems-with-booting/
14 minutes ago, Mad153 said:
Welcome to the forum!
have you tried clearing the CMOS?
Thank you
so my motherboard do not have a clear cmos button but i took out the cmos battery and after i did that i heard it could be bad idk, but yes i did try to clear the cmos.
https://linustechtips.com/topic/1170699-problems-with-booting/#findComment-13422745
5 minutes ago, Botte02 said:
Thank you
For future reference you can clear the CMOS\ by using a screwdriver or other metal tool to jump the CMOS pins for five seconds. You can find the pin layout in the motherboard manual.
https://linustechtips.com/topic/1170699-problems-with-booting/#findComment-13422756
yeah i read that after made me feel a little stupid.
thank you though
https://linustechtips.com/topic/1170699-problems-with-booting/#findComment-13422762
