Hey guys,
I'm trying to build a gaming pc for light gaming and streaming. I have a budget of about 850 for just the PC. I want to play games like Rainbow Six Siege at 1080p and 60fps. I built this on pc parts picker and wanted a second opinion on it from people who know more than me. any help is appreciated! Thanks!
https://linustechtips.com/topic/1170602-first-pc-build/
$100 is about what a 1TB SSD would run you, so an $85 SSD with only 500GB is hard to justify. This would serve a lot better.
https://pcpartpicker.com/product/6j448d/western-digital-blue-500gb-m2-2280-solid-state-drive-wds500g2b0b
Also the RX 580 matches the 1650 super in performance, so if you spy either for cheaper, choose whichever costs less.
Edited by Fasauceome
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1170602-first-pc-build/#findComment-13421841
Overall seems like a decent build. If you want pure gaming performance I would recommend getting a Ryzen 1600 AF (basically the same as a 2600 but for $85) and a more powerful graphics card. You may also want to consider a stronger psu if you go that route.
Mesh Devil
AMD Ryzen 3600 | MSI b450 Tomohawk MAX G.Skill Ripjaws 2x8 3200mhz
Powercolor Red Devil RX 5700 xt
Samsung 860 EVO 500 GB | Seagate Barracuda 2 TB
Corsair RM650x
Fractal Design Meshify C Tempered Glass
https://linustechtips.com/topic/1170602-first-pc-build/#findComment-13421849
3 hours ago, spike47p said:
-snip-
Probably be better served with a 1TB SSD:
PCPartPicker Part List
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  ($174.99 @ Newegg)
Motherboard: MSI B450 TOMAHAWK MAX ATX AM4 Motherboard  ($114.99 @ Best Buy)
Memory: G.Skill Aegis 16 GB (2 x 8 GB) DDR4-3000 Memory  ($67.99 @ Newegg)
Storage: Crucial P1 1 TB M.2-2280 NVME Solid State Drive  ($109.99 @ B&H)
Video Card: MSI Radeon RX 580 8 GB ARMOR OC Video Card  ($154.99 @ Newegg)
Case: NZXT H510 ATX Mid Tower Case  ($69.99 @ Best Buy)
Power Supply: Corsair CXM (2015) 450 W 80+ Bronze Certified Semi-modular ATX Power Supply  ($64.99 @ Newegg)
Total: $757.93
Generated by PCPartPicker 2020-03-30 02:37 EDT-0400
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/1170602-first-pc-build/#findComment-13422322
The PSU will do fine, even with a Vega 64 and high end i7.... the PSU is not the concern.
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/1170602-first-pc-build/#findComment-13422324
If you cheapen out some items, you can fit a RX 5600XT relatively well.
Motherboard: MSI B450-A PRO MAX ATX AM4 Motherboard  ($99.99 @ B&H)
Storage: Western Digital Blue SN550 500 GB M.2-2280 NVME Solid State Drive  ($64.99 @ Newegg)
Video Card: Gigabyte Radeon RX 5600 XT 6 GB WINDFORCE OC Video Card  ($279.99 @ B&H)
Case: Cougar MX330 ATX Mid Tower Case  ($45.99 @ B&H)
Total: $798.93
Generated by PCPartPicker 2020-03-30 02:40 EDT-0400
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/1170602-first-pc-build/#findComment-13422331
i'd go with a 1660 super build
https://linustechtips.com/topic/1170602-first-pc-build/#findComment-13422537
