So odd situation I never encountered. My CPU temps have been a bit warm for my liking since I built this pc (idle at 80c) with my stock intel cooler. Now here is the weird part. I just ran a cpu stress test because I wanted to see if my temps rise and they dont rise too much when gaming. But here is where the weirdness comes in, after the stress test my CPU started running cooler by a lot. Now it runs at 50-60c when idleing and under load doesnt go higher then 78c. So what's the deal? Wondering if I should be concerned.
https://linustechtips.com/topic/1170311-cpu-temps/
How are you monitoring temperatures? What CPU do you have?
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
https://linustechtips.com/topic/1170311-cpu-temps/#findComment-13419286
I use cpu real temp or whatever it is called as well as afterburner. Only use both cause I wasnt sure if afterburner was giving me right temp so I verified with the second application. My cpu is an intel i7-3770.
https://linustechtips.com/topic/1170311-cpu-temps/#findComment-13419402
