I need someone to see if my upcoming build parts are balanced
Ryzen 5 2600X
Wraith Spire cooler from r5 2600x package
MSI B450 Tomahawk Max
EVGA GeForce RTX 2060 6GB KO Ultra Gaming
G.Skill Sniper X 16GB(2X8GB) DDR4 3600
some sata ssd and hdd i can find at my local store
Phanteks P300 ATX Mid Tower
SeaSonic 520 W 80+ Bronze Certified Fully Modular ATX Power Supply
be quiet! SilentWIngs 3pwm 120mm and 140mm
btw im playing modded minecraft
https://linustechtips.com/topic/1170214-advice-pls/
The M12ii is ancient, see if you can get a CX550 or pure power 10/11 instead.
Get a 1600AF or 2600 and overclock it instead.
https://linustechtips.com/topic/1170214-advice-pls/#findComment-13418482
You can save money with the not MAX version of the tomahawk. The max usually costs a little more, because it's updated for Ryzen 3000.
Trash beauty:
CPU: Xeon X5550
GPU: RX 570 4GB (defective)
SSD: Fattydove Racing 240GB
HDD: WD Blue 320GB
Motherboard: HP Z400
Ram: 6x2GB DDR3 1066
PSU: Corsair TX650
https://linustechtips.com/topic/1170214-advice-pls/#findComment-13418556
i could find a CX550M in my region but no pure power 10/11
Is the CX550M any different from the CX550? And i what way?
https://linustechtips.com/topic/1170214-advice-pls/#findComment-13418589
but the non max version can only support ddr4-3466 but the one im planning on is ddr4 3600
also max is all black which fits my theme
https://linustechtips.com/topic/1170214-advice-pls/#findComment-13418612
Partpicker does not have ryzen 5 1600 AF for some reason. It is 40 dollars cheaper than r5 2600 but will perform same.
One of the cheapest b450 boards (ATX) but still decent thermals and look.
Little better ram that you had there.
cheap 1tb ssd and 2tb hdd
5600 XT will perform the smae as rtx 2060 but it is cheaper.
The phanteks case only has one fan at the pack. Mount one of those 3 arctic fans at the top for outtake. Mount 2x fans to the front for intake.
Decent power supply.
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1170214-advice-pls/#findComment-13418657
Why would you change the board ? The op had the Tomahawk which is far better and cost a few $$$ less. Makes no sense to go with that Asus one.
I would buy a case with a few more fans pre-installed. The CoolerMaster MB520 for example is $89.99 but comes with 4 fans.
https://linustechtips.com/topic/1170214-advice-pls/#findComment-13419558
