So i have this big issue where my GPU is sucking. I have a msi gtx 1080ti gaming x trio with a Ryzen 7 2700x and 16gb of corsair 3200 ddr4 ram. And when playing games my fps is very bad. My card is not reaching its full potential, and the fans on the GPU are not even coming on, Ive updated drivers checked to make sure the bios was up to date and even tried old drivers  Take battlefield 5 for example in max settings i should be getting around 150 frames, i am barely breaking 60. I do understand bf5 is a CPU intensive game and GPU utilization is extremely Low, but i watched a video with someone that's got the same CPU but a 1070 and hes getting better fps than me.  and thats not the only game it happens in. I am extremely frustrated, and need help. I also cant get the osd with msi afterburner to display temps and and cpu/gpu usage in game, it did it once but never again. Thx in advance for any help. Its greatly appreciated
https://linustechtips.com/topic/1168909-plz-help-gpu-issues/
Not at all.
It's a GPU intensive.
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/1168909-plz-help-gpu-issues/#findComment-13406873
When you say you should be getting 150 frames per second in BF5, at what resolution are you playing it at? Is it 1080P or 1440P? Have you checked in Nvidia Geforce to make sure the target frame rate isn't locked at 60? At 1440P max settings, you're not gonna get 150 fps with your setup in games like BF5, not quite.
GTX 1080 TI Battlefield V | 1440p | i7 8700K | Ultra Settings:
System Specs
  • CPU
    AMD Ryzen 7 5800X
  • Motherboard
    Gigabyte AMD X570 Auros Master
  • RAM
    G.Skill Ripjaws 32 GBs
  • GPU
    Red Devil RX 5700XT
  • Case
    Corsair 570X
  • Storage
    Samsung SSD 860 QVO 2TB - HDD Seagate B arracuda 1TB - External Seagate HDD 8TB
  • PSU
    G.Skill RipJaws 1250 Watts
  • Keyboard
    Corsair Gaming Keyboard K55
  • Mouse
    Razer Naga Trinity
  • Operating System
    Windows 10
https://linustechtips.com/topic/1168909-plz-help-gpu-issues/#findComment-13406887
MSI Afterburner as OSD keys to choose make sure that and gpu temps, usage are selected to show it as well on rivatuner must have osd set on either the low or medium setting for application detection level. Then in game hitting the key you set or not it should show up. BF5 is gpu intensive, so I'd also recommend setting a decent fan curve to keep the card cool enough to pull as much mhz as you have with what you have OC settings to.
If your fan aren't turning on that's a whole other issue with the card itself or something is nvidia control panel. There settings in there too to boost performance. Just FYI I use texture filtering quality set to high performance. Don't worry it effects no game graphics.
I just played RE3 DEMO with everything max on my 1070 ti. Well around 100 FPS. However RE engine one of a kind. Like seeing everything sweat pore on them is just insane and the lighting is glorious.
First watercooled System
Build Name: White Knight
OS: Windows 11 Pro 64-bit
Monitor: Alienware AW3423DWF 1800R Curved Ultrawide 3440x1440 QD-OLED 157hz 10 bit 0.1ms
Chassis: Lian Li 011 Dynamic EVO w/ 2x120mm Corsair QL RGB Fans on the bottom 1x120mm on back exhaust
Top Rad & Fans:  Corsair 54mm 360mm w/ 3x120mm Corsair ML Pro RGB Fans
Side Rad & Fans: Corsair 30mm 360mm w/ 3x120mm Corsair QL RGB Fans
Motherboard: Asrock X670E Steel Legend
CPU: AMD Ryzen 7 7800X3D w/ Corsair XC7 RGB Pro w/ Kyrosheet
Memory/RAM: Corsair Dominator RGB DDR5 2x16GB 32GB 6000Mhz
GPU: Asus GeForce RTX 4080 TUF w/ EK-Quantum Vector2 Nickel/Plexi & Backplate
Pump/Reservoir: Corsair XD5 RGB
Coolant: Corsair Clear
PSU: Lian Li Edge 1000W
Boot/OS SSD: Samsung 970 EVO Plus 500GB NVMe
WZ/2042 SSD: Samsung 850 EVO 250GB
Game SSD: Samsung 980 Pro 1TB
Performance/Editing HDD: Western Digital Black 1TB
Storage HDD: Western Digital Blue 1TB
Mouse: Razer Lancehead Tournament Edition/Razer Mamba
Mouse Mat: Corsair MM700 RGB
Keyboard: Razer Ornata Chroma
Microphone: Beacn Mic
Headset: Razer Blackshark v2 Pro
Eyewear/Glasses: Gunnar Optiks Razer FPS/Gamer Advantage Liquid
Camera: Razer Kiyo Pro/OBSBOT Meet SE
https://linustechtips.com/topic/1168909-plz-help-gpu-issues/#findComment-13406888
12 hours ago, threadripper said:
it is in 1080p
Then yes, you shouldn't have a issue. Your card is not keeping itself cool it seems. Your saying no fans come on try to turn them on in afterburner manually. If they don't turn on by their self when playing games. You can also try a benchmark or download OCCT it has gpu test built in.
How are you using NVIDIA control panel defaulted? It should be on "use the advanced 3D image settings".
https://linustechtips.com/topic/1168909-plz-help-gpu-issues/#findComment-13410437
