my friend wants to be able to run titan fall on medium settings for under 500$ CAN go.
i was thinking this http://pcpartpicker.com/p/2Uzlg
please suggest other options
if you are reading this you are wasting valuable time and should maybe rethink your life choices.
https://linustechtips.com/topic/116854-build-for-a-friend/
You definitely don't need that PSU. I would recommend going with something in line with this product instead.The rest of the build isn't too shabby. Might want to change up a few things to save a dollar or two, but all in all it's decent.
Now, medium settings might be pushing that APU a little - although I'm not entirely sure.
Edit: @Evostatic343 - I know this isn't exactly pretty or insane, but this falls pretty close to his budget: $550 CAD Build
Pew Pew Helicopters
https://linustechtips.com/topic/116854-build-for-a-friend/#findComment-1560335
PCPartPicker part list: http://ca.pcpartpicker.com/p/2UA8D
CPU: AMD Athlon X4 750K 3.4GHz Quad-Core Processor  ($88.32 @ TigerDirect Canada)
Motherboard: ASRock FM2A85X Extreme4-M Micro ATX FM2 Motherboard  ($115.00 @ Vuugo)
Memory: Corsair Vengeance 4GB (1 x 4GB) DDR3-1600 Memory
Video Card: Asus Radeon R9 270 2GB Video Card  ($215.00 @ Canada Computers)
Power Supply: SeaSonic S12II 430W 80+ Bronze Certified ATX Power Supply  ($69.98 @ Newegg Canada)
Total: $488.30
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-02-16 23:00 EST-0500)
CPU AMD Ryzen 5 3600x | GPU GIGABYTE GTX 1070ti WINDFORCE | MOBO ASUS Prime X570-P | MEMORY XPG Spectrix 2x8GB 3200MHz  | PSU OCZ Zx 850W | CASE NZXT H440
https://linustechtips.com/topic/116854-build-for-a-friend/#findComment-1560355
Total: $488.30
I'm pretty sure that OP's friend needs more than just the basics. It looks like he needs an entire build minus the peripherals. Now, if I'm mistaken and he has parts to use already, this is definitely a fairly solid build idea. I wouldn't try to find more of a balance between the parts, however - you have a lot of the cost wrapped up in the GPU and PSU that don't need to be.
Pew Pew Helicopters
https://linustechtips.com/topic/116854-build-for-a-friend/#findComment-1560379
Holy balls this was hard!
PCPartPicker part list / Price breakdown by merchant / Benchmarks
Motherboard:  ASRock FM2A55M-HD+ Micro ATX FM2+ Motherboard  ($53.50 @ Vuugo)
Memory:  A-Data XPG Gaming Series 4GB (1 x 4GB) DDR3-1600 Memory  ($43.00 @ Vuugo)
Storage:  Seagate Barracuda 500GB 3.5" 7200RPM Internal Hard Drive  ($54.79 @ DirectCanada)
Video Card:  Asus Radeon HD 7770 GHz Edition 1GB Video Card  ($111.00 @ Vuugo)
Case:  Apex SK-393-C ATX Mid Tower Case  ($24.48 @ DirectCanada)
Power Supply:  EVGA 430W 80+ Certified ATX Power Supply  ($29.99 @ NCIX)
Operating System:  Microsoft Windows 8 (OEM) (64-bit)  ($89.88 @ Canada Computers)
Total: $494.96
(Generated by PCPartPicker 2014-02-16 23:10 EST-0500)
https://linustechtips.com/topic/116854-build-for-a-friend/#findComment-1560396
Total: $494.96
Ah, best build right here. If he can invest a little more into RAM, he'll have a very good machine for the price. Good call on the 750K - I never even thought about that.
Pew Pew Helicopters
https://linustechtips.com/topic/116854-build-for-a-friend/#findComment-1560405
Total: $494.96
Was gonna post mine but the only difference was the mobo and a differently branded 7770.
CPU: i7 5820K 4.0GHz @1.15V | MOBO: Asus X99 Sabertooth | GPU: Gigabyte Windforce GTX 980Ti, LTT Orange | CASE: NZXT H440 Black 2015 | COOLER: Noctua NH-D15S w/ LTT Fans | RAM: 32GB Patriot 3000MHz | STORAGE: 512GB Samsung 950 Pro, 960GB Sandisk Ultra II 3 x 8TB Seagate HDD's | PSU: 750W Seasonic X series, black / orange cablemod cables| Monitors: 3x Asus VX24AH's | AUDIO OUT: Microlab SOLO 8C, Sennheiser HD 650's, Audio engine D1 Amp / DAC | AUDIO IN: Blue Snowball | Keyboard: CM Storm QuickFire TK MX Green | Mouse: Logitech G900 Proteus Spectrum + RSI Extended Mouse Pad | PCPP Linkhttp://nz.pcpartpicker.com/list/hPjFd6
https://linustechtips.com/topic/116854-build-for-a-friend/#findComment-1560409
