Hello,
Recently, I bought an additional Ram kit 2x8GB DDR4:
I have 24GB Ram with the new 2x8kit ( So i have on  Ram Slot 1&3 8GB Ram and on Ram slot 2&4  4GB RAm)
My problem is that My Ram frequency now is on 2400 Mhz after the upgrade with the 2x8 ram, before that the Ram frequency was on 2666 Mhz. I already checked the UEFI and there is still the profile with 2666Mhz selected.
I assume that probably the voltage is too low ( I am scared to change the voltage as I don´t want to damage anything)
I think that it also can be normal that at 24 GB Ram the speed will go down.
My PC specs are:
*i5-8600k
*Gtx1060 6Gb Vram
*MSI Z370 Mainboard
*2x4GB Ram CL16 2666Mhz
*2x8GB Ram CL16 3200Mhz
If you have any suggestions feel free to tell me.
Nuyrux.
https://linustechtips.com/topic/1168434-problem-with-ram-frequency/
1 hour ago, nuyrux said:
Hello,
My PC specs are:
*i5-8600k
*Gtx1060 6Gb Vram
*MSI Z370 Mainboard
Nuyrux.
Have you tried restarting your computer and does the problem apparent when you go to task manager and check your ram specs?
My Rig:
CPU: Intel i5 2500k 4 Cores, 4 Threads @ 4.5ghz ( asus uefi regulates BIOS and adjusts it, there is no manual option, so I can't get any higher than 4.5, but I theoretically should be able to get higher once I get a voltage "changeable" mobo
MOBO: Asus P8Z68 LE
RAM: Kingston HyperX Predator 2133mhz ddr3 2x8 16GB
GPU: GTX 980 TI 150+ core, 100-150 ( I forgot )+ mem ( OC )
HDD: 500GB 3D MLC Samsung SSD ( soon ) + 2tb 7200rpm Seagate Constellation ES.2 SAS / LSI MegaRaid MR Raid/SAS Controller
CASE: Phanteks P350X
OS: Windows 10 64-bit / Void Linux
PERIPHERALS: IBM Model M 1984, Logitech G703 Mouse, Logitech G502 Mouse, Philips SHP9500 w/ V-Moda Boom Pro hooked up to my Sony AMP ( forgot model name, to lazy to find out )
Laptop: Gateway P-7805u FX
CPU: 2.26GHz Intel Core 2 Duo P8400 2c/2t
RAM: 8GB DDR2 1066mhz sodimm
GPU: Nvidia GeForce 9800M GTS
HDD: 320GB 7200rpm hard drive 2.5"
SSD: Kingston A400 250GB SSD
SCREEN: Glossy 16:9 1440x900
OS: Windows XP SP3 / Ubuntu 19.04
PERIPHERALSLogitech G Pro
