So It's late and my brain isn't working also I've not run FAH for a while so any help is appreciated.
if I run
sudo /etc/init.d/FAHClient start
I get
Starting fahclient ... FAIL
if I run
sudo /etc/init.d/FAHClient log
I get
02:05:06:  <!-- User Information -->
02:05:06:  <team v='223518'/>
02:05:06:
02:05:06:  <!-- Folding Slots -->
02:05:06:  <slot id='0' type='CPU'/>
02:05:06:</config>
02:05:06:Switching to user fahclient
02:05:06:Trying to access database...
02:05:06:ERROR:Exception: Database version is 16 but this program only supports 13
I'm on 7.4.4 which from what I can tell is the current client
https://linustechtips.com/topic/1167727-fah-linux-help/
See the Alternative Downloads at the F@H site.
sudo apt install ocl-icd-opencl-dev
wget https://download.foldingathome.org/releases/public/release/fahclient/debian-stable-64bit/v7.5/fahclient_7.5.1_amd64.deb
sudo dpkg -i fahclient_7.5.1_amd64.deb
sudo wget http://fah-web.stanford.edu/file-releases/public/GPUs.txt -P /var/lib/fahclient/
sudo service FAHClient start
See the Linux HOWTO in my sig for hints under Ubuntu Bionic Beaver
6 GPU Folding Rig  Linux Folding HOWTO Folding Remote Access Folding GPU Profiling ToU Scheduling UPS
Systems:
desktop: Lian-Li O11 Air Mini; Asus ProArt x670e WiFi; Ryzen 9 7950x; EVGA 240 CLC; 2 x 48GB DDR5-6000; 2 x Samsung 980 Pro 500GB PCIe3 NVMe; 2 x 8TB NAS; MSI RTX 4070 ti Super; AMD FirePro W4100; Corsair SFF750
nas1: Fractal Node 804; SuperMicro X10sl7-f; Xeon e3-1231v3; 4 x 8GB DDR3-1666 ECC; 2 x 250GB Samsung EVO Pro SSD; 7 x 4TB Seagate NAS; Corsair HX650i
nas2: Synology DS-123j; 2 x 6TB WD Red Plus NAS
nas3: Synology DS-224+; 2 x 12TB Seagate NAS
dcn01: Fractal Pop Silent XL; Gigabyte Aorus z570 Master; Ryzen 9 3950x; AMD Wraith; 2 x 16GB DDR4-3200; 256GB NVMe; Gigabyte Gaming RTX 4080 Super; MSI 4070 Ti Super Gaming X; Corsair RM750e
dcn04: Fractal Define S; Gigabyte Aorus ax570 Master; Ryzen 9 5950x; BeQuiet! PureRock 2; 2 x 16GB DDR4-3200; 250GB NVMe; ; Gigabyte Gaming RTX 4080 Super; MSI 4070 Ti Super Ventus 2; Corsair TX750M
https://linustechtips.com/topic/1167727-fah-linux-help/#findComment-13397831
