So I recently bought a second gtx titan black. I also bought and sli bridge to go with it. I know sli isn't the best in 2020, but it was a good deal for the second one. I installed them and the sli bridge, open nvidia control panel to configure sli, but it's not there. Both gpus show up in control panel and also device manager, but the configure sli isn't there. I also don't want to use two different sli auto because I'm not so sure about it and it also seems annoying to install. So if anyone could help that would be great.
https://linustechtips.com/topic/1167593-sli-not-working-help/
12 minutes ago, TruDruChocolateMilk said:
tried clean install and yes it is correct
Did you check the I'd numbers for both the you'd they have to be the same for them to be able to work in sli
CPU: 6700K Case: Corsair Air 740 CPU Cooler: H110i GTX Storage: 2x250gb SSD 960gb SSD PSU: Corsair 1200watt GPU: EVGA 1080ti FTW3 RAM: 16gb DDR4
Other Stuffs: Red sleeved cables, White LED lighting 2 noctua fans on cpu cooler and Be Quiet PWM fans on case.
https://linustechtips.com/topic/1167593-sli-not-working-help/#findComment-13395690
1 hour ago, TruDruChocolateMilk said:
they are the founders addition cards so yes
It doesn't matter if they are founders editions or not. Same model cards can have different device id numbers based on their production run. I had to rma a gpu to evga over this in the past when I had dual 780's. Actually check and make sure then come back and tell me if it's the same. Go into Nvidia control panel and click on system info and scroll down till you see Device ID. These numbers can be different regardless of model or brand.
Make sure you click on both gpus listed on the left after clicking system info and check both. They both won't appear in the same window when you open system info in Nvidia control panel.
https://linustechtips.com/topic/1167593-sli-not-working-help/#findComment-13396150
