Sudden Frame Drop
23 hours ago, Delacroixgaming said:They are already to 100%.
But I guess I found the problem.
So, basically my gpu was giving me fake temps because the thermal compound was completely worn out.
I opened my gpu(Rog strix 1080), and I noticed what the hell was going on.
So yeah, make sure you check the thermal paste, or get it checked by a professional.
Sometimes the solution is so obvious that it hurts.. Lol.
Pics for proof:
The card had basically zero contact with the cooler.
I still don't know why It was giving me fake temps, but now all is good.
Rock solid 45° celsius when I play, with fans at 100% cause Overclock.
Nice! glad you were able to solve your problem. The fans solved our problem, we just made them more aggressive. JUST got done with a 2 and a half hour gaming session and having the fans at 90% was enough to prevent it from bugging out again. I might check his thermal paste on his GPU next time I see him in person as well though, since the temperatures are still off, we just set the fans more aggressive.
