4 minutes ago, Pyrx said:
Just picked up a new matx motherboard, just wondering if I was to buy a case would it come with all the panel connectors for that board?
You'd have to look around for a schematic of the F_PANEL header, but most cases should have individual connectors so having the pins in the right order shouldn't be a problem.
I think Lenovo uses an extra row of non-functional pins on their USB headers, but the header is otherwise the same. I have a USB expander from an old Lenovo desktop that I can check.
The one thing to note is that this board has no USB 3.0-- you'd have to either get a USB3-USB2 header adapter, a dedicated USB3 card, or just be OK with any USB3 ports not working if you get a case that uses USB3.
https://linustechtips.com/topic/1167511-panel-connectors/#findComment-13394976
That board lacks USB 3.0 because it pre-dates USB 3.0
I hope you realize how antique that board is (8 or 9 years) and didn't pay too much for it (<$20 with the I/O shield) if you plan to build a "retro build".  I hope you can find the Sandy Bridge CPU and DDR3 RAM  you need to use that thing.
Anyway..
Pin 1&2 is HDD
Pin 6&8 is PWR LED
Pin 10&12 is PWR SWITCH
I don't believe the ThinkCenter M92 had a reset button.
99% of the time, "LPT" means printer port.  See.. back in the day, printers actually had their own port and didn't use the USB port (probably because USB 2.0 was too slow).
https://linustechtips.com/topic/1167511-panel-connectors/#findComment-13395048
