Hello everyone,
My Gtx 1650 (Single channel 2400mhz cl17 Ram, i5 9300h, 512gb SSD) is runnin gon a to low Usage in some games. For example on 50% on CSGO or 70% in Pubg. In some games my gpu is only at a 40% usage. Its deffinately not a Bottleneck and i dont really think that its cause of the Single Channel. Ive done Like everything ive seen so war but nothing has helped me. Sry for my bad english smile.gif.
Best wishes
Leon
https://linustechtips.com/topic/1167349-low-gpu-usage/
Because why?
you are running that DIMM @ 1200Mhz cl 17 obviously its the ram that is bottlenecking you couldnt go any slower than that...
https://linustechtips.com/topic/1167349-low-gpu-usage/#findComment-13393658
3 minutes ago, papajo said:
Because why?
Wow Thats really bad. Isnt there any way to get the Gpu´s Usage any higher? My laptop only has one Ram Slot so i cant run it in dual Channel. Will i get some Improvment if i would buy a 16gb 2666mhz cl15 Ram stick?
https://linustechtips.com/topic/1167349-low-gpu-usage/#findComment-13393670
You must have a slot to add a second DIMM then whats the laptop's brand and model?
As for increasing GPU usage if your hardware isnt strong enough to push it there isnt much you can do
What you can do is change the performance settings
  (some of those settings will come to a cost of your battery life)
also take a look here
https://www.makeuseof.com/tag/5-ways-improve-laptop-gaming-performance/
https://linustechtips.com/topic/1167349-low-gpu-usage/#findComment-13393695
Its really only one Ram Slot. Its the Lenovo L340 15IRH 81LK. Ive tried every Battery setting there is and went much further. Ive done every Nvidia 3D settings Optimazations too. Some games use 99% of my Gpu too, For example War Thunder or World of Tanks.
https://linustechtips.com/topic/1167349-low-gpu-usage/#findComment-13393699
well if you buy something like this it wouldnt hurt https://geizhals.eu/?cmp=1505766&cmp=1798038
and considering your signle channel situation certainly will aid to game performance as well.
https://linustechtips.com/topic/1167349-low-gpu-usage/#findComment-13393747
isnt this one better?
https://www.amazon.de/HyperX-HX426S15IB2-16-Impact-Arbeitsspeicher/dp/B01N7K4DV4/ref=cm_cr_arp_d_product_top?ie=UTF8
And will it really help me get more Gpu usage?
https://linustechtips.com/topic/1167349-low-gpu-usage/#findComment-13393751
2 minutes ago, leon555 said:
its a fast ram but the ripjaws 3000 cl 16 is faster
usually ram doesnt play a huge part in game perfomance but judging that your bizzare laptop has 1 channel of ram and its a very slow ram you will see some FPS increase with faster ram for sure.. just get in contact with lenovo to be sure that it can support faster ram
furthermore 16 GB is a better capacity because games need ram chrome browser needs ram the iGPU of your laptop is goignt to use 2GB of your ram... so 8 is kinda small to begin with
https://linustechtips.com/topic/1167349-low-gpu-usage/#findComment-13393760
Ok good but is the speed really good enough to utilize the lack of dual channel? and my Laptop sadly only supports 2666mhz.
https://linustechtips.com/topic/1167349-low-gpu-usage/#findComment-13393766
well I cant say for sure... its a very strange issue for me to know exactly how things will turn out.
The memory is  faster in speed and in latency to your current one so it will perform better
and it would be better in general to have more than 8GB (especially since 2 of them are reserved by the iGPU)
https://linustechtips.com/topic/1167349-low-gpu-usage/#findComment-13393781
The memory wi faster in speed and in latency to your current one so it will perform better
Well ok, Thank you for taking your time for my Problem, i hope the new Ram stick will fix this.
https://linustechtips.com/topic/1167349-low-gpu-usage/#findComment-13393783
dont expect a huge performance leap though it will be better though
Now you know never to buy a single channel laptop if you are interested in gaming
https://linustechtips.com/topic/1167349-low-gpu-usage/#findComment-13393791
actually when you install the new RAM please post performance differences just out of curiosity :P
yes i will that will be interesting cause i cant find ANYWHERE a comparison in 1x8gb ram vs 1x16gb ram and i think that will be interesting. And i didnt knew before that its only single channel :/
https://linustechtips.com/topic/1167349-low-gpu-usage/#findComment-13393799
On 3/22/2020 at 7:31 AM, leon555 said:
But i still need some help ive seen Peoble get a 100% Usage on the same Laptop in for example CSGO.
why are you fixated on the gou usage on not the machines performance.
the gpu usage stat is just the ammount of time the gpu is busy , not the % at which it is being used
https://linustechtips.com/topic/1167349-low-gpu-usage/#findComment-13399063
