3600 would be more efficient in photo manipulation
https://linustechtips.com/topic/1167251-help-with-a-decision/#findComment-13392931
You wouldn't want to put a 1660 Super generally with a 75hz 1080p monitor anways.
3600 would be the better all-rounded choice.
As a wise master once said,
Put as much effort into your question as you would expect a stranger to add to their answer!
Desktop: AMD Ryzen 5 3800XT | Gigabyte X570 Aorus Ultra | Corsair Vengeance LPX 32 GB 4000Mhz CL18 | MSI RX 5700 XT Gaming X | Two WD Black SN750 1TB NVMe SSD | Corsair AX850 Titanium | Fractal Design Define 7 White, Solid
Laptop: Apple Macbook Pro 16 | i9 9980H | 16 GB RAM |  1TB SSD | AppleCare+ | Space Grey
Peripherals: RAMA U-80 Lake | Logitech MX Master 3 | Kanto YU2 White + Beyerdynamic DT 177X GO
Displays: LG GX 55"| Acer XB273K | Dell Ultrasharp U2720Q | LG 32UN650-W
https://linustechtips.com/topic/1167251-help-with-a-decision/#findComment-13392937
So go for the lower end gpu and better cpu and monitor?
https://linustechtips.com/topic/1167251-help-with-a-decision/#findComment-13392957
Yeah. You'll be able to upgrade to something more high end if you feel like it as well.
2600 should only be really paired with up to a 2070 Super.
https://linustechtips.com/topic/1167251-help-with-a-decision/#findComment-13392961
