48 minutes ago, Chodzik said:
So that didn't change anything, the bios setting was already set to PCI-e but the other slot is pci-1, would that work or not?
If you plug in a video cable(hdmi or dp) into the gpu and get a picute FORGET ABOUT BIOS.You install the driver from the nvidia site and that should be it and you will see in dev manger gtx 1650 instead of microstoftbasic display adapter
