14 minutes ago, timmie33 said:
I bought a lapboard from corsiar with a k63 keyboard and a rgb harpoon mouse but when I put it in the pc directly it works fine but when I use a extention cable it fails to work what can I do to make it work?
Do you know the length of the extension cable? USB 2.0 cables cannot be longer than 5 metres, that's 16ft 5".
Quote
is there a way to extend those limits? Yes! However, in order to go beyond these cable length limits (or recommended lengths) you need to use self-powered USB hubs or active (repeater) cables; both of which have their own limits as well. Other options such as USB over Ethernet or building your own USB bridge can extend the USB range further.
https://linustechtips.com/topic/1166912-extention-cable/#findComment-13390386
