Audio through an HDMI splitter?
On 3/20/2020 at 6:22 PM, Inked Angels said:Thank you so much Derkoli!
One source out of two devices.
Press the windows button/start, type "Control panel" in, then select Control panel.
Go to hardware/sound, then select Sound.
Select "Speakers (or Realtek)" as the playback device.
Go to the "Recording" tab, right click and enable "Show Disabled Devices"
A device called "Stereo Mix" should show up
Right click on the new device and click "Enable"
Right click on the new device and click "Set as default device"
Double click on the new device to open the Properties window.
Go to the "Listen" tab.
Select the "Listen to this device" check-box.
Select the HDMI output from the "Playback through this device" list.
Now, you should have audio output on both Realtek and the HDMI output of your GPU/iGPU. If Windows behaves.
