Hello I am looking into getting a budget 24 IPS 144hz (1ms) monitor now I been looking around and they all seem to false advertising the 1ms aspect. Anyways if you had $175 for a monitor what one would u get any why.
https://www.amazon.com/MSI-Non-Glare-Super-Narrow-Bezel/dp/B083K17XLH/ref=mp_s_a_1_3?dchild=1&keywords=OPTIX+G241&qid=1584603934&sr=8-3
https://www.amazon.com/ASUS-VP249QGR-Monitor-FreeSync-DisplayPort/dp/B083FMP35T/ref=mp_s_a_1_5?dchild=1&keywords=OPTIX+G241&qid=1584603934&sr=8-5
https://www.amazon.com/Pixio-FreeSync-Certified-1920x1080-Warranty/dp/B07TYSMMVX/ref=mp_s_a_1_14?dchild=1&keywords=OPTIX+G241&qid=1584603934&sr=8-14
The Aoc 24g2 is not available and the Acer Nitro VG240Y Pbiip is over my budget
https://linustechtips.com/topic/1166288-help-me-choose/
Just look for more detailed reviews, but they might just all  be using the new 1ms IPS panel that came out recently.
https://linustechtips.com/topic/1166288-help-me-choose/#findComment-13385198
I personally would go with asus, as I've never had a problem with their displays, and it has freesync. Finding any 144hz IPS panel with 1ms response times is hard. I believe that there are newer panels that allow that, but I wouldn't hold my breath for anything super cheap at 1ms and IPS.
Edit cuz I put acer instead of asus
Edited by piratemonkey
Either @piratemonkey or quote me when responding to me
https://linustechtips.com/topic/1166288-help-me-choose/#findComment-13385206
Not sure between the MSI and Asus, but I would avoid the Pixio since it has a curved screen. In my opinion a 24" monitor should not be curved, its too small for the curve to be beneficial.
https://linustechtips.com/topic/1166288-help-me-choose/#findComment-13385220
