Help with new Ryzen PCs
Solved by Streetguru,
24 minutes ago, Wreighn said:@Streetguru 3600mhz CL16 is out of my price range (32 is not absolutely necessary, but it gives me peace of mind when working with VMs). I'd be willing to reconsider the size if speed and timings make too great of an impact.
@piratemonkey Just how important are the timings? The gskill ones I listed have CL16-18-18-38. How much would that impact performance.
Then 3000mhz CL16 should be fine, might be able to overclock it a bit anyways.
it's harder to run 32GBs at higher speeds in general as well.
it's maybe a 5% difference in some games, so it's not too huge.
