Best 90mm fan?
Go to solution Solved by LukaP,
Yeah this is perfect, but do they have any with blue LEDs?
not sure, it was just a quick look.
basically search for "90mm fan" on any site you want, and try to get one that hasnt got sleeve bearings and youre pretty much golden :)
Hey guys, I've got all but one of the fan mount sections used up in my PC. The only one left is for a 90mm fan, if anyone knows some good 90mm fans then I would appreciate the help. Please include links.
Here are the websites I will accept
Amazon
Canada Computers
NCIX
Newegg
Tiger Direct
Thanks.
https://linustechtips.com/topic/116547-best-90mm-fan/
[AMD Athlon 64 Mobile 4000+ Socket 754 | Gigabyte GA-K8NS Pro nForce3 | OCZ 2GB DDR PC3200 | Sapphire HD 3850 512MB AGP | 850 Evo | Seasonic 430W | Win XP/10]
https://linustechtips.com/topic/116547-best-90mm-fan/#findComment-1556853
"Unofficially Official" Leading Scientific Research and Development Officer of the Official Star Citizen LTT Conglomerate | Reaper Squad, Idris Captain | 1x Aurora LN
Game developer, AI researcher, Developing the UOLTT mobile apps
G SIX [My Mac Pro G5 CaseMod Thread]
https://linustechtips.com/topic/116547-best-90mm-fan/#findComment-1556855
That is the slim NF-A9x14. If a standard 25mm fan fits, the NF-B9 PWM is better in almost all regards ;)
hehe i just like the look of the A9 more to the B9 since it doesnt have the holes between the blades :)
https://linustechtips.com/topic/116547-best-90mm-fan/#findComment-1556865
How about some fans more on the cheaper lines, Maybe some blue LED fans?
Would 92mm work on my case? The description says that I can install one 125mm fan and one 90mm fan.
Here is my case http://www.canadacomputers.com/product_info.php?cPath=6_112&item_id=032151
https://linustechtips.com/topic/116547-best-90mm-fan/#findComment-1556907
Would 92mm work on my case? The description says 90mm, here is my case http://www.canadacomputers.com/product_info.php?cPath=6_112&item_id=032151
http://www.newegg.com/Product/Product.aspx?Item=9SIA2XC11F4878
somehing like this then?
https://linustechtips.com/topic/116547-best-90mm-fan/#findComment-1556931
https://linustechtips.com/topic/116547-best-90mm-fan/#findComment-1556953
Okay thanks.
anytime
https://linustechtips.com/topic/116547-best-90mm-fan/#findComment-1557068
