Display troubleshooting Help (I promise this wont be a pain)
1 hour ago, Scorpio 72472 said:Is there anyway I can test it without me replacing the motherboard just for the sake of checking. (hardware enthusiast senses are tickling me :)) )
PS: I love the meshify series
If you know someone with a compatible board you can test your components on their board or test their components in yours, CPU, GPU, and everything. The only other test I think you can run that you didn't is testing both GPUs in another PC. You've done every diagnostic/fix I would suggest. It's not software as you have done both DDU and a fresh Windows install, and if both GPUs exhibit the issue it's most likely not them, after GPU I'd say monitor, but you've ruled that out as you've used a different HDMI as well as tested on a completely different monitor where it did the same thing, that's not it. If it's not software, GPU, or Monitor it leaves the other hardware. CPU doesn't really make sense but it is possible. The pcie slot being bad on the motherboard makes the most sense to me. I think your next step if both GPUs work in another computer is motherboard replacement. If you have a Bestbuy or Microcenter nearby buy one from there as they have good return policies and will normally be pretty chill if you have to return the new one, if you do not have a local store that sells motherboards or you do and it does't have a good return policy, order from Amazon.
