I just build a pc but I overlooked a small detail. My case has a front USB-C port which requires a USB 3.1 Gen 2 connector with my motherboard doesn’t have :(. I was looking into two options on adding an additional header that might work.
1) https://www.bhphotovideo.com/c/product/1495446-REG/silverstone_ecu02_usb_type_c_3_1_pcie.html/?ap=y&gclid=Cj0KCQjwpLfzBRCRARIsAHuj6qXPpFOXtunHN-YgeBg6-lPNl7rAHWNNWENq0C2XUBtfjzvLuFExEUAaAtVrEALw_wcB&lsft=BI%3A514&smp=y
or
2) https://www.shentek.com/product/1-port-internal-usb-c-usb-3-1-gen2-10g-m-2-card/
Option 1 looks more promising but there’s no real specs on the other hand option 2 looks shady as hell. Has anybody tried either solution? Or maybe there an alternative that I haven’t seen?
My motherboard is Asus X570 Tuf Gaming plus wifi.
https://linustechtips.com/topic/1165349-usb-31-gen-2-header-solution/
