Hi all LTT community,
I've just got a rather curious question regarding RAM/Memory speeds. Looking at the memory speeds listed below, is there really that much difference between them?
Memory Speed List
• 1333MHz
• 1600MHz
• 1866MHz
• 2000MHz
• 2133MHz
• 2400MHz
• 2600MHz
• 2800MHz
• 3000MHz
I realise it looks like there would be a massive difference but in reality, is there really much of a difference at all?
Thanks in advance for your help guys. :D
ON A 7 MONTH BREAK FROM THESE LTT FORUMS. WILL BE BACK ON NOVEMBER 5th.
Advisor in the 'Displays' Sub-forum | Sony Vegas Pro Enthusiast & Advisor
  Tech Tips Christian Fellowship Founder & Coordinator
https://linustechtips.com/topic/116488-rammemory-speed-question/
If you stay in the same CAS, yes but it's minimal.
Cost doesn't scale either. 1866 is usually the sweet spot.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/116488-rammemory-speed-question/#findComment-1556127
Nope, none. No difference at all.
I mean, realistically, physically, there's a difference. However, for performance for 90% of user machines, there is no real difference.
The 10% are APU machines and Workstations that actually need fast RAM.
I personally prefer my RAM to be 1/2 my CPU speed (Because that's what the RAM speed is relevant to).
† Christian Member †
For my pertinent links to guides, reviews, and anything similar, go here, and look under the spoiler labeled such. A brief history of Unix and it's relation to OS X by Builder.
https://linustechtips.com/topic/116488-rammemory-speed-question/#findComment-1556131
Unless you know your workload requires fast RAM, you probably don't need fast RAM. The extra speed will give minimal improvements in terms of gaming.
Personal Rig
i7 4790K | Asus Z97I-WiFi | CM 280L | Sapphire R9 290X Tri-X | Kingston ValueRAM 2 x 8GB | 128GB Samsung 840 Pro | 2TB Seagate SSHD | Seasonic Platinium 660W | Bitfenix Prodigy
https://linustechtips.com/topic/116488-rammemory-speed-question/#findComment-1556240
I don't suppose Video Editing in SVP would require speedy RAM, would it?
https://linustechtips.com/topic/116488-rammemory-speed-question/#findComment-1556255
yes there is a difference. It depends on how you value them. On workload that require fast ram and specially to the self satisfaction of seeing you got fast ram. IMO for me and If I had the cash I'd splash em on the fastest memory I can get just for the sake of satisfying my self.
truth to be told I can't afford them sadly.
Live your life like a dream.
https://linustechtips.com/topic/116488-rammemory-speed-question/#findComment-1556263
It may. There are many variables, and I frankly do not know. More research is needed. My hunch is if the rendering is on the CPU, fast ram may help, but if more things are offloaded to the GPU, it will make less of a difference. But that is all a guess though.
Personal Rig
https://linustechtips.com/topic/116488-rammemory-speed-question/#findComment-1556269
