Hey there! Sorry in advance if this is a dumb question!
I've been searching (and failing) at finding a solution to a problem that's been fairly annoying over the past couple months.
I have a pair of bluetooth headphones that I need to switch between 3-4 different devices multiple times throughout the day.
At some point between hopping devices, usually what ends up happening is that a given source (pc / mac / phone / etc) fails to auto reconnect and I have to reset my headphones into pairing mode and re-pair which gets painfully tedious to the point that I just usually find myself reaching for a 3.5mm cable and switch that between the devices instead.
Does anyone know of anything akin to an HDMI switcher that could be used for audio devices w/ bluetooth connectivity?
Thanks!
https://linustechtips.com/topic/1164822-bluetooth-audio-splitter/
