3900X 3600 C18 memory won't run at speed
Solved by rorythedawg,
On 4/5/2020 at 12:26 AM, semo said:I'm starting to think this is the best approach, RMAing is just such a pain. Would you for sure do the motherboard first? I've no way to tell if it's the CPU or MB.
Thanks for the help
mobos are much more likely to be faulty than your cpu out of the box. that being said you bought a pretty good mobo so it might be a toss up. if you have any buddies with am4 you could test your cpu and ram on? If not you could order a very cheep am4 mobo off amazon. It should be sufficient to check ram stability.
Even though RMAing is annoying it may be your best bet at this point not to waste money on other gear to test this out. If you do RMA your parts do all of them to be safe.
