Hello,
I have a problem with (I think software but maybe isn't the case) but I don't see the OS Troubleshooting section anywhere so I'll post here.
Ok so, I was doing some coding when suddenly I got a Windows popup saying that 2 USBs had an error: device descriptor request failed.
I couldn't find anywhere the solution to my problem because everyone says - do that in the registry edit then unplug your USB device.
I can't bro. No USB devices were plugged in specifically to cause that error. It just randomly happened by itself and no USBs were in during that time!
I'm just really confused and I really need help, I would really appreciate if somebody could help me! Thanks.
https://linustechtips.com/topic/1164394-help-problems/
