So my brother and my friends all wanna build custom pc rigs and i guess i should too but were all new to this and i'm entrusted with making the part lists so im on pc part picker when i realize im heavily out of my league
So i need parts for 4 computers and each computer has a different set budget and basically it's like this..
My Brother's Budget: 1500 / This is including a monitor but not a mouse and keyboard and he want's to do video editing for his youtube channel and he wants to do gaming
My Budget: 500 / No peripherals needed but i want to do gaming and maybe streaming
My Best Friends Budget: 300 / Not including peripherals but he wants to do streaming and gaming
My broke friends budget: 150 / Not including peripherals just needs to play things like CSGO and Fortnite and Siege on low settings with playable framerates
i know a little bit about pcs but if i could get some sample builds to work off of that would be greatly appreciated!
https://linustechtips.com/topic/1164389-need-help-building-a-couple-computers/
I'm going to focus on the lower end builds as I'm sure someone else will get the 1500$ list set up for you. If they don't I'll throw something together
For your limited budget I'd go with a 1600AF and a used 580 (or similar card):
PCPartPicker Part List
Type Item Price
Motherboard MSI B450M PRO-VDH MAX Micro ATX AM4 Motherboard $79.99 @ B&H
Memory OLOy WarHawk RGB 16 GB (2 x 8 GB) DDR4-3000 Memory $62.99 @ Newegg
Storage TCSunBow X3 480 GB 2.5" Solid State Drive $57.99 @ Amazon
Video Card XFX Radeon RX 580 8 GB GTS XXX ED Video Card $100.00
Case Cooler Master MasterBox E300L MicroATX Mini Tower Case $39.99 @ Amazon
Power Supply Corsair CX (2017) 450 W 80+ Bronze Certified ATX Power Supply $38.98 @ Newegg
Custom 1600 AF $85.00
  Prices include shipping, taxes, rebates, and discounts
  Total (before mail-in rebates) $484.94
  Mail-in rebates -$20.00
  Total $464.94
  Generated by PCPartPicker 2020-03-12 18:37 EDT-0400
For both of your friends I would look at buying a used Dell Optiplex with an i5 or i7. There's no way to buy a decent new system for 300$ for those processes.
For your limited budget I'd go wit ha 1600AF and a used 580 (or similar card):
Type Item Price
  Total $464.94
This is good advice, and for the rich friend id go with this list
Honestly i didnt think to change to a 3700x lol, only difference is a lower clock speed but thats not much of a deal. saves some space for the better gpu and bigger ssd, although you couldve gone with a better monitor and kept the 500gb ssd
I just made some more changes. I'm sure 50 bucks won't kill em.
Just now, NotSaint14 said:
That motherboard says it has an incompatibility issue
That's because when the 3xxx ryzen chips were released, they weren't natively supported on B450. The Tomahawk MAX boards have the bios update out of the box that supports those chips.
7 minutes ago, NotSaint14 said:
So this is kinda what i have going on rn for my brothers build do i need to buy a windows boot drive as well?
You will need to get a windows license, yes. Also knock the power supply down to a 650w TXM unit.
Also if i could get someone to help me with those lower end builds that would be really nice too
Where do you need help with those?
Also make sure to quote when you respond - so we get notified.
You're going to be hard pressed to find anything around $150 that can do much of any gaming.
For $300 you'd need to go used, for example, maybe something like this could work: https://www.ebay.com/itm/IBUYPOWER-504-ITX-Gaming-PC-i7-4770-3-40GHz-16GB-256GB-SSD-1TB-GTX-780ti-Win-10/293508719740?hash=item44567ba47c:g:R5AAAOSw7RJeaor1
2 minutes ago, NotSaint14 said:
i was wondering if there is another board for the 1500 build cuz my brother isn't gonna trust me when i say it's compatible if pc part picker doesnt say it is
Show him this thread and my reply then. I run a similar system.
Need to know what i should be working on with those builds
And as mentioned, used dell optiplex, or a used system off your local classifieds.
Look for a 4th gen i7 or newer, with something like an RX 570 or similar gpu.
