Hi guys,
I'm looking to build a PC based in the UK. (so i get the lovely high prices). My pc will be a for gaming and need it to be compact for my uni room. My gaming range is quite broad but not overly excessive on pc performance. My budget is around £650-£700. I'm not too bothered with 244hz or gaming above 1080p so any monitor i'm quite happy with. I have a keyboard mouse headset ect so really concentrating on monitor and pc (i have os key). Primarily i'm looking at a ryzen system a 5 2600x or 5 3600, and a gtx 1650s. Any recommendations or changes? (this is what i was looking at so far)
the prices here aren't exactly right this build comes to £661.75 on the UK Amazon.
Thanks guys!
https://linustechtips.com/topic/1164337-first-pc-build/
If at all possible I'd recommend you go for the GTX 1660 Super. Performance-wise it's close to that of the base RTX 2060 but without the ray-tracing capabilities.
MoBo: Aorus Z370 Gaming 5 (rev. 1) | CPU: Intel Core-i5 8600k | GPU: ZOTAC RTX 2070 Super 8gb Twin Fan | RAM: 2x 8gb Corsair Vengeance RGB Pro 3200MHz | Cooling: Cooler Master Hyper 212 RGB Black Edition | PSU: Thermaltake Smart Pro RGB 650w 80-Plus Bronze | Storage: 1x ADATA 120gb SSD + 2x Seagate Barracuda 2tb HDD | Case: Corsair Carbide 275R (white)
https://linustechtips.com/topic/1164337-first-pc-build/#findComment-13368766
just 2 things i advice
1 get a mid tower case, it is a nightmare trying to build in those mini ones(i know you need a small build but the mid tower aren't that much bigger than the mini ones)
2 consider any gpu with 8gb of ram in it, although not super important but if you play any badly optimized games it will impact performance a ton (like pubg)
https://linustechtips.com/topic/1164337-first-pc-build/#findComment-13368778
If you can go slightly over your £700 limit.
PCPartPicker Part List
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  (£151.88 @ Amazon UK)
Motherboard: MSI B450M MORTAR MAX Micro ATX AM4 Motherboard  (£87.98 @ Amazon UK)
Memory: Crucial Ballistix 16 GB (2 x 8 GB) DDR4-3000 Memory  (£69.98 @ Amazon UK)
Storage: Western Digital Blue 250 GB 2.5" Solid State Drive  (£43.32 @ Amazon UK)
Storage: Seagate BarraCuda 1 TB 3.5" 7200RPM Internal Hard Drive  (£33.96 @ Amazon UK)
Video Card: PNY GeForce GTX 1660 SUPER 6 GB Video Card  (£194.99 @ Amazon UK)
Case: Thermaltake Core V21 MicroATX Mini Tower Case  (£59.99 @ Amazon UK)
Power Supply: Corsair TXM Gold 550 W 80+ Gold Certified Semi-modular ATX Power Supply  (£64.98 @ Amazon UK)
Case Fan: ARCTIC F14 PWM PST 74 CFM 140 mm Fan  (£8.19 @ Amazon UK)
Total: £715.27
Generated by PCPartPicker 2020-03-12 20:00 GMT+0000
https://linustechtips.com/topic/1164337-first-pc-build/#findComment-13368814
